1 - 9 of 9 Posts
Porting the exhaust runners out. I think I made them Too big. Everyone kept telling me "Gasket match, Gasket match", well I made them a little smaller than the gaskets but when I put that same gasket up to the new headers, the header tubes are a lot smaller.
Is my exhaust going to be hitting a brick wall now?
Should I start looking for some more E7TE's?
Well, I think I'm finished with the heads. I'm sure more could be done but I'm getting tired of messing with them.
I bolted one header up and ran my finger around the short turn and ran into the slag on the header.
I'm not a welder so forgive me for asking, but is it OK to grind that down to make it flat? or will it weaken the weld?
Here's one of the exhaust ports.
One more.
Grind down the weld and if you cut through, reweld on the outside - just don't interfere with the bolt areas. You need to be able to get the bolts in after you weld.
Be sure to remove your slag with a ding hammer/center punch/wire wheel and put high temp paint to keep your metal from rusting away.
1 - 9 of 9 Posts
