Are they these?
If so you should have no clearance issues, Tim runs that same setup and he said he has .180 on the intake and .200 on the exhaust; of coarse your cam will affect the actual clearance but you should be fine, this is the same setup I am putting together
Ok, just thought I would add that these are hypers, you probably have different pistons but if they are cut for 1.90 valves then there should be no issues
<font size=-1>[ This Message was edited by: mikemustang289 on 3/12/06 4:07am ]</font>
