In the process of removing all the trim on my 67 ford galaxie 500 . I need to remove the vent window to get at the 2 remaining screws on the bottom behind the vent window in order to remove trim that goes across door.
Also, can someone help me on how to remove trim that goes across the top of windshield.
Thanks !!
Not sure what year you are working on but if you remove the door panel it should be easy to figure out how to remove the vent window. There is only a bolt or two holding them on. Someone else can help with the windshield trim. Just let us know the year and inside or outside. I'm assuming outside trim.
