Is the F stop a good source for switched 12 volts? Was thinking about using it to fire the choke on my carb.
Thansk for any help
I have had great luck running the choke off of the + terminal on the coil, but if the S terminal works, that is probably better.
the volT reg has lettered connectors, one is labeled F.
valleydude is the s on the alt fired when the key switched to on? or does the motor need to be running?
only works when the motor is running that way the choke doesnt pull off if the car dies as it gets no signal without the car running , I have my road demon hooked up this way and it works well.
