I'm being told that I can use the master from a 66 galaxy 500 for my 66 Thunderbird, has anyone here done this? Any advice on the subject is appreciated.
I don't own a T-Bird but I do own a 66 Galaxie with power drum brakes.
The 66 Galaxie master is a single reservoir "jam jar" same as your T-Bird.
While the Galaxie master might swap to the T-Bird, what's the point?
It would not be an "upgrade".
In 67 Ford went to dual reservoir masters across the board.
I am using a 67 Galaxie power drum brake master in my 66.
It bolts in with the exception of modifying the hard lines.
Likely a 67 T-Bird dual reservoir master would work for you but you need to specify drum or disk brakes.
You will also have to modify the hard lines.
Thanks I appreciate the heads up I'm looking to do a double reservoir, car sat for a number of years and just looking to make it a little more road worthy
