1 - 9 of 9 Posts
HELLO ALL ! Needing the rear axles for my 64 Galaxie 500 fast back. 28 spline old axles measure 27 3/4 " and one measures 32 1/4" long for the outside the hub(where the wheel goes on) to the end of the axle.
e mail me at [email protected] or call me at 618-977- nine 1 six 5.
Thanks !
Red
Do you need the small bearing or big bearing 28 spline axles
The bearings I need are around 3 inches and some change..I did not measure the bearings , but was told that is what I needed.
Without measuring ,I'd say I needed the big bearing axles. I can measure whatever it is if that helps.......
I think the easiest way about this is to ID your axle bearing:
If your old rear axle bearing has a number on it like: RW207 plus several letters, it's the small, or more correctly as the 'book' calls it: medium
The size is: 2 53/64" O.D.
If it has a number on it like: 88128 preceded and/or followed by letters, that's the large bearing only found on h/d rear axles.
The size is: 3 5/32" O.D.
If you have numbers on your bearing that for some reason aren't either one of these, fret not, you can post them here and folks will try to cross-reference them, or you can try a place like NAPA and they will cross them.
Also, 1960-64 28 spline Gal axles are the same, given, they're the "medium" bearing as determined above.
Maybe that will help in your search?
OK Norm, the bearing has FS 88128 on it, so it sounds like it is the large bearings.
Yup, I agree -plus, you mentioned your bearing is over 3", so that cinches it.
ps: I know of an all Ford yard down in SE MN, but that may be kinda far. I did check the St Louis area craigslist since I'm on there alot, but nada.
Have you considered buying a complete rearend, I would consider it.....cuz it might be easier to find, altho... the down side is you don't know what shape it's in until dis-assembly .....just my (out loud) thoughts on it, lol. :)
I quick-looked at Moser, Currie and Yukon too.
Good luck on your search! Norm
Sorry, can't help you either. I also have a big bearing housing in mine and i have 2 sets of small bearings axles but no extra large bearing axles
Discussion Starter #9
Thanks for all the help folks ! I found some axles in Conn.
1 - 9 of 9 Posts
