I've been searching high and low for a drivers side window regulator for my '63.5 Falcon hard top. If anyone has one or knows of a source, please hit me up!
Thanks in advance.
Thanks in advance.
Hey BlueBird. Thanks for the link, but they only carry the regulator for the sedan and convertible, which doesn't fit the hardtop. It's a narrower bolt pattern and the stud where it attaches to the scissors is male, not female, so it's reveresed from the hardtop version.
Are we talking about the FRONT or REAR window? I can't imagine Ford would have made a different door for each body style...Hardtop and Vert should be the same piece.Hey BlueBird. Thanks for the link, but they only carry the regulator for the sedan and convertible, which doesn't fit the hardtop. It's a narrower bolt pattern and the stud where it attaches to the scissors is male, not female, so it's reveresed from the hardtop version.
I looked at a few pics of the Mustang regulators on eBay and they do look really similar, with the exception of an arch in the arm that connects to the scissors. The aftermarket Mustang ones are cheap enough that it wouldn't kill me to buy one and then use it as a zombie braining device if it doesn't fit.I do believe the 63-65 are the same in which case one from a 65-66 Mustang will work. I took mine apart, repaired and cleaned it and it has been working good for a few years now. I had some photos if I can find them.
add: do a search for window regulator on here and TFFN
ONLY at Ford...........Not to Hi-Jack the thread, but I wonder how much more profitable FoMoCo would have been if the Powers That Be had used a little common sense and made more parts common among all their product lines??? Not to mention BIG parts like.....bellhousings.....IMO one of the big reasons GM passed Ford in easy, convienent hotrodability....that and motormount commonality.I'm looking for the driver's front. The regulator for the hardtop is different from the convertible and the sedan.
Many driveline, suspension, steering components on the Falcons are compat with the mustang. Also you have rear ends from Maverick's, Disk Brakes from Granada's that have been transplanted with ease to the Falcon due to compatability.ONLY at Ford...........Not to Hi-Jack the thread, but I wonder how much more profitable FoMoCo would have been if the Powers That Be had used a little common sense and made more parts common among all their product lines??? Not to mention BIG parts like.....bellhousings.....IMO one of the big reasons GM passed Ford in easy, convienent hotrodability....that and motormount commonality.
That was exactly the point I was making...not to mention all the small stuff, trim pieces that are exclusive to one model or another....door and window crank handles...sunvisor brackets..arm rests and their bases, would anyone even noticed or cared back in the 60's if the Mustang, Falcon and Fairlane had the same armrests ro visor brackets? FoMoCo could have just as easily altered a new design(screw holes or mounting pad) to match parts already on the shelf.(parts they had already designed and paid tooling costs for)....For that matter, how about outside door handles...tiny differences that keep them from being interchangable...Well I think Bikes was referring to the interchangeability from I6-SBC-BBC... not having to find a different trans for every change makes sense, unlike the Ford lines, except for a few of the rarer earlier stuff between the MEL/FORD lines that was being discussed in another thread. ( IE:SBF has "early/Late" patterns, FE BB another, 385 BB ANOTHER.)Sure a turbo350 aint the best behind a high hp/tq BB but by gosh it'll BOLT UP. And the mounts are slightly different but can usually be made to work by just moving the stands to the "other" holes..... Not needing whole differently engineered stands for a SB-BB change....
Just sayin...
