It will be difficult to find-
It will be difficult to find-They actually made 2 diffrent 400 blocks? Or are you confused as to what you really want?
Not that I'm all knowing but I've never heard of an FMX block...
KULTULZ, I dont know eacatly what your saying here but I have a bellhousing off a 77 Ford F-250 that had a 400 in it. I am using this bellhousing on my 400 and its mated to a Tremec TKO 600. The only modification to the trans is a shortened input shaft to fit a stock bellhousing.
Now I am really confused. The bellhousing I showed was a 460 that would accept an FMX. I thought that was the direction the discussion was going in.On a side not all 77-82 Ford Trucks with a 400 or a 351M with a standard had a bellhousing that would fit a SBF trans. They have the same bolt pattern. I am also using the flywheel that came from the same truck.
OEM 4V intake for a 351M/400?I was just saying that there is a small block trans pattern bellhousing out there. One thing I have leanred about Ford is neer say never. If you can dream it Ford has done it.
Now you know I am going to ask you to document that statement don't you?The OEM 4V 400 intake does exist, I have seen pics of it.
Let me clarify this statement, it seems my lips got in the way of my eye teeth and I could not see what I was saying...The FMX block also had the small block engine mount pattern. There are a couple of reasons they are sought after. But thanx for the info...![]()
I have seemed to cause a lot of confusion...nothing new...You are not questioning the existence of a 385series pattern bell housing for a c-4 are you, I have one in my garage now. I guess that is what I am reading here.
Completely plausable. I have also heard of a limited release of 4V BRONCOS. Hard to distinguish between fact and wives tales but you have the first proof I have ever come across...I have heard a couple of these stories as well. The one that seems to hold the most water was about a fleet of 77 LTD II cop cars sent to a midwestern Police agency. As the story goes the engines were junk and the blocks kept cracking so they junked the lot of them. The reason it seems to hold water is that around the same time a Police agency in California got a fleet of these cars but with the the 2bbl manifold etc.
As denoted by the XE casting number this manifold is a experimental and was never ment to see the light of day as far as public use. Still I wonder how many were cast and on what cars or trucks they were tested on.
Can I get the Casting I.D. No. and Date Code off that manifold?Please disregard the second pic, it is of a 351C with a holly flange on it.
