351 windsor to a 351 Cleveland Will it just drop in and fit or do I need to redo mounts shock towers ect???
good info on weight for Ford parts... I don't think 100Lb is a real number...
BTW yes the Windsor today can make a lot of power, but you will notice
that Jon Kassi uses a Cleveland block, in the Engine masters series.
Also the block is not in favor with NASCAR, wonder why?
Do a goggle on Dan Jones... he is a Cleveland master...
Best of both worlds, Clevor. Windsor short block, Edelbrock 7183 intake, 61699 or 61695 heads. This is actually the setup NASCAR Ford teams use. I know a guy that uses this at the dirt track. Chevy people hate him. 60cc chambers make flattop pistons easy. With Alum int and heads, you'll loose 70 lbs off the engine. Making you lighter then a 289.
