1 - 16 of 16 Posts
HI ALL
I was reading the artical in Mother Earth News and it said to mix 4 to 1 water to alcohol.. But it doesn't say what kind of alcohol.... White lighten, rubbing, or alcohol fuel. It does say its mostly just to stop it from frezzing up.. So can I use the Heat stuff (gas line antifreezz) for water in the gas tank or what??
http://journeytoforever.org/biofuel_library/ethanol_motherearth/me3.html
thanks
tim
ALWAYS THE RED NECK WAY
61 Comet W/200
http://img522.imageshack.us/img522/6415/comet2bj.jpg
64 International 4dr. truck w/466
<font size=-1>[ This Message was edited by: pedal2themetal45 on 12/1/06 4:28am ]</font>
Yep, winter mix washer fluid works best, it usually has more alcohol.
You guys are funny...
run soap thro your motor
LOL
Actually, washer fluid is an alcohol and water mix.
I don't know where YOU get washer fluid with soap. If you did the washer pump would make it foam!
OH
I always thought there was soap in it..
tim
One would think so, but no.
Unless you use the RainX brand. There's more than just methanol and water in that stuff.
Rain X has other chemicals in it in order to promote beading and visibility on your windshield, even after the stuff has long dried =). It almost pushes the water off the windshield itself. Nice stuff, that's what I run, period.
Cris
I don't think you would want any thing "beading up" in your engine, though. Why spend the extra dough for the expensive stuff, if you don't need it? I thing the El Cheap-o stuff from Wal Mart should suffice for a buck.
Once you use rainx always rainx.
I use it on all my windows, but do not use the washer fluid. I have had no luck with it in the washer tank, it always leaves a film. You can always tell when someone doesn't use Rain-X, you just can't see worth a crap.
Yeah, tell me about it.
I need to re-RainX the Volvo. Passengers start panicking when its anything more than sprinkling. It really makes a huge difference.
Bet it doesn't burn too well though.
1 - 16 of 16 Posts
