im building my stroker and on the engine in the car now is a weiand action plus manifold and im wondering if it would be worth the money and would make a noticable difference if i switched to a performer or performer rpm manifold or some other type of manifold
thanks jeff
the cars purpose? How many inches, what head?
what cam amd what induction as well...
The weiands are a good choice if the other parts match as well but thats true with any combo
its a 347 mostly street and then just some trips to the strip every one a while the heads are world products r200 (roush 200) heads the cam if a flat teppet crane z-cam .504 intake .518 exhaust and a 650 demon vac secondary carb
thanks jeff
Performer RPM.
I don't think your stroker will run as good as you want it to with the Action Plus. I've seen the Performer....It looks pretty small to be putting on a stroker. I think you would be much happier with the Performer RPM or the Weiand Stealth.
I have seen the RPM performer pick up 26 H P on a 425 H P motor. The air gap is only a few H P better if you do not have an exhayst crossover in your heads. JOE SHERMAN RACING
