I broke in a new cam a few days ago and I started having some white goo coming out of the back of the engine. I thought at first it was water in the oil as it was burning on the headers, but I drained the oil and it was all oil and no water. I put in shell rotella T, comp break in additive, and I used the red cam grease comp sends with their cams. I don't think I wiped a lobe or anything as all adjustemts were good when I checked them today. But in the valve covers is a white substance that looks sort of like water and oil mixed, but doesn't smell like water and oil. Is this the break in additive? I know I need to redo the intake because the back leaks oil. The oil pressure was adequate, just not sure whats going on.
Hmmm... Still could have been water... intake may have pissed a tiny bit when you broke in the cam... Is it really humid there at the moment?
White + oil = water....
must be the intake, i'll redo it.
Cleaned everything out, wasn't too much white junk everywhere. Ran the engine for a while after I reinstalled the intake and there is no more water. Engine runs pretty decent now, lost just a little bit of bottom end but picked up a good amount in the mid and upper ranges to make up for it.
Ive read something about edlebrock intakes, (air gap) and felpro 1250 gaskets being a bad combination. It concerns the water passeges not lining up correctly.
Whats a bummer for me is that when i finally fire my setup ill probably have the same issue as i have that combo (Edle Air gap/Felpro.)
Just a thought.
I have an Air-Gap on my 331 with 1250 gaskets. I just completed a cam swap and didn't see any evidence of the water passages not lining up. I bought another set of 1250 gaskets and fired it up with the new cam today and it all looks fine.
i believe it was ckelly who documented the AirGap/felpro problem on his website. I could be wrong though.
I remember that. I think that had to do with the GT-40 heads.
did you use the comp cams engine assy grease on the bearings? i recall that being a white grease like substance. i used it before and saw similar results in the oil. it works well for initial start up/break-in but change oil immediately and don't use too much of it....unlike the comp cams red goo you put on the cam lobes, can't get enought of that. ciao.
