HI ALL
What are the pros and cons of welding up a rear end instade of get a locking mech.
Thanks Tim
Discussion Starter · #2 ·
OOPS
its mostly daily driver but some strip time.
Tim
Why weld it when you can do the same thing with a mini spool?
but you aren't going to like it when you go to turn corners and have to replace the tires every 6 months or so.
96 Ford F350 PSD CC DRW
97 Ford Taurus
64 Fairlaine 500 rust bucket/future Tbolt clone with 514 BBF
<font size=-1>[ This Message was edited by: Just Strokin on 6/11/02 2:09am ]</font>
or replace axles.....
Dont do it. Go with some sort of limited slip or locker.
When you go around a corner, the outside wheel has a longer path to follow. With both of them turning at the same speed, something has to give.
Now the advantages- Great traction.
Disadvantage- You cant turn without chirping a tire, or something worse... Get a locker instead, they only chirp the tires on really hard turns.
THANKS ALL
I guess I go with some sort of locker or a posi.
Tim
