i will be there.
i will have a black w/ a white 4" cowl hood 91 saleen there in i guess the renegade class. it has a 357"w, track heat heads, victor efi upper/lower, 75 mm t/b, custom comp retro roller, nitrous works 260 hp 2-stage plate, 3800 10" no2 converter, homebuilt c-4 (thanks to gregaust
, anderson performance pms efi tuner, 8.8 axle with spool, moser alloy axles , 4.10 gears...hope it's enough just to make the 32 car cut??
<font size=-1>[ This Message was edited by: rj on 5/13/02 12:23pm ]</font>
I am planning to be there. I plan to run in the Open Comp class. 88LX with Cleveland. The Stang is light tan with a black hood scoop.
