What would be the strongest pushrod small block for the money? 69 351W? Something that will survive 500 rear wheel HP on the street? A dart block is way to expensive.
You would be fine with one of those blocks.
<font size=-1>[ This Message was edited by: cmf60 on 11/12/06 7:00am ]</font>
The only problem is that the early blocks have a shorter deck...which can throw you a curve if you're doing a stroker. I'm right in the middle of doing one now...haven't figured out how to use a 4.000" stroke with my C9 block...and use the pistons I have now. Might change directions & go with 6.300" rods and 331 pistons.
I believe it's the 71-74 blocks that are most desirable. Same strength as early blocks, with the proper 9.503 deck height.
Cris
I like the 86 5.0 roller block personnally. You can find a good seasoned block out of a lincoln for cheap cheap plus you can use a roller cam without the mods. I used 351W heads first C9's. Anything prior to 74 is a decent 351 head... decided to go with X303's when I couldnt make the numbers I was after and am now happy...
parts list:
86 HO block 5.0L
KB115 pistons
ARP 5/16 wavelock rod bolts
checked deck / line bore
everything else stock
application:
68 mustang coupe
current numbers - 350HP / 375 ft/lbs torque - flywheel
<font size=-1>[ This Message was edited by: dekrev on 11/12/06 8:48pm ]</font>
parts list:
86 HO block 5.0L
KB115 pistons
application:
68 mustang coupe
The trouble is that the 302 won't last very long on the street when pushing 500hp at the wheels, which is the original poster's intent.
Dennis
65' STANG, 3160 lbs
393W NA, 2.78 Toploader 4 Spd, 9" 3:70 Posi
Pro Comp Heads, Vic Jr. Intake, 750dp, 236/561 Solid Cam, 9.6CR, 1 3/4" Headers, Lakewood, Subframes, Caltracs
<font size=-1>[ This Message was edited by: dennis111 on 11/12/06 10:09pm ]</font>
