Cams Hmmmm, no easy answer huh? 5.0HO stroked out to 347ci, going with AFR 185 w/standard springs, Staying Fuel Injected, What kind of cam will I need?
Also what's a good bearing for cams and cranks?
I use Comps extreme energy hyd rollers alot with those engines...but I swap out the std. springs in favor of the beehive's.
Caming an engine should be a well thought out process taking EVERYTHING into consideration to get the most out of any engine so take your time and use someone who's done engines like yours.
Brian
Custom cam. Is too important to guess.
The guy at summet said a trickflow kit would be a good Idea. It included the heads, Intake, cam, chain, gears push rods, gaskets,ect. Has anyone had good luck with those?
I'm a Trickflow dealer, and I've only sold one of those kits because a customer insisted on it. He hasn't got it running yet but it should'nt be long...
If you do this, I would use their cnc ported TW heads...Tooley does their cnc stuff!
Brian
