I have a 1993 ford 1/2 ton p/U 2 wheel drive with a 302 engine & the local Ford dealership can not tell me what trans I have>> the numbers are top row --PKB BF>>>> second row --012674 H12>>>> third row --F3TP AA >>> Thanks in advance >>>Jim >>>fordsemi >> all this came on a tag bolted to the trans >>Thanks
i dont belive the ford garage could NOT TELL you what trans you have
Catalog No.
20569915
Product Name
AUTOMATIC TRANSMISSION
Manufacturer
FORD
Vehicle
93 FORD F150 2WD 8 cyl
Engine Size
5.0
Notes
10 1/4" Ext Hsg
VIN Codes
N
Tag ID
PKB-BF
Transmission Model
AOD
Discount Price
US$ 854.93
Core Deposit*
US$ 250.00
Shipping & Handling
US$ 175.00 (Round trip shipping
Discussion Starter #4
Hi.. The parts man said it could be one of 4 trans.. Again Thanks to ALL.. Jim>> I wrote all this down>>> Thanks
ya but not with a VIN code "N".What is your VIN CODE???
How can I identify the VIN code of my Transmission?
If your vehicle was manufactured between 1975 to 1980, the VIN/Transmission code is the 5th digit of your VIN number.
If your vehicle was manufactured after 1980, the VIN/Engine code is the 8th digit of your VIN number
If the pan says METRIC and "automatic overdrive", then it is an AOD, if it just says METRIC, than it is an AODE. Also check to see if it has two linkage arms on the drivers side--AOD or just one with a plastic neutral safety switch---AODE
