I was looking at the powertrax for the detroit trutrac. Which is better for a street driven 71 torino with a 408cleveland and a tremec 5 speed with 3.50 gears. Also can I install it myself if not how much should I expect to pay. Thanks
so what one will hold high hp, but not push round corners, i am looking to get detroit, but i want to be certain it wont push on corners, yet be tough as heck and lock up good when needed, i guess there should be different clutch friction choices huh?On 2006-03-13 07:24, DrStang wrote:
I have the Powertrax no-slip installed. At times, I'm completely happy with it, other times I'd like to toss it.
It may ratchet in tight turns, sometimes not. Otherwise, its a locker and you get the benefits from it.
You will feel that it pushes you in the turns a bit.
Anyone here have experience with the detroit truetrac limited slip?On 2006-03-18 14:27, 71hotrodpinto wrote:
Check out the detroit truetrac.
http://www.detroitlocker.com/DT.htm
I dont know anything about it but from what ive read its the one im saving up for.
Happy hunting
That sounds great; how long have you had them in your truck?On 2006-03-19 19:27, smokey212 wrote:
I've got the true trac in my toyota rock crawler. I doesn't see a lot of horsepower, but it does get a good shock from trying to climb huge rocks. I'm running about a 220hp 280 ftlb toyota supra engine in the truck, so it does get yanked on.
Oh yeah, I've got it in the front and rear, and it's quite on the street ,and only lets the wheel slip less than half a rotation before it locks up.
<font size=-1>[ This Message was edited by: smokey212 on 3/20/06 10:28am ]</font>
