I have a 289 and switching from stock cast heads to afr 165's
I have flat top pistons and trying to determine which head gasket to use. Is there a rule of thumb distance that you should not go below in terms of clearance between piston's and valves? Thanks for any input...
I use .080 on the intake and .100 on the exhaust
