Allmost time to put the back glass back in my 64 Futura. I have a new rubber seal molding for it so what kind of sealer are you guys using ? Are you sealing the molding to the glass before you install it ? Do you seal it to the body as you install it or after it's installed ? Need some instructions here on the correct easy to use sealers and not make a big mess. I thought the silicon stuff would be hard to work with ,is there some thing better?
When i put the back glass in my 56 Fairlane i never used any sealer and it's never leaked after sitting out all the time for 12 years now. But i'm not sure if i should do the Falcon that way.
