1 - 20 of 36 Posts
Workin on the 4x4 for a daily driver for me and the family (Ranger is WAY too small for the wife and me when you add a car seat) Also trying to get my KZ finished for summer.
Right now I am getting my 67 F250 up for towing duty. Among other things, I'm installing a G/V overdrive unit and putting in a larger aux gas tank.
I've been working on something "feminine" to sit in the passenger seat of the mustang.
wear a wedding ring. They all come runnin as soon as they cant have ya...
I've worn the ring for 10 years.
I'm not putting one on again until "Mrs. Right" comes along.
Im slowly getting pieces together for my 4 speed swap. Im haggeling parts and getting 4 speed console, hump, pedals, steering column and wheel, ac condensor/drier, radio, plus a few small pieces. Hopefully have the ac hooked up and 4 speed parts ready for install (if I can find a good priced 4 speed).
Rick
New slicks are on. About the only thing left is some waxing/polishing, some new sponsor decals, and adjust the valves.
OH yeah, maybe change plugs and wires.........
I'm so bored.....................
Discussion Starter #16
Hey Travis, what kind of combo are you working on?
Well, a fellow had been bugging me about my 514 for sometime and the price was right to get rid of it and start on a new combo. Its a C-460 headed 557 this time. 13:1 compression, flat top pistons, roller cam,cast single four intake with 1050 dominator and homemade headers 2"-2 1/8"-2 1/4" into a 4" collector. Hope it will run some 10.0's on the motor of course
Had to do something to keep up with the Cooks and Mike 545's of Fordmuscle, not to forget Chilly 460 too.
And I did say keep up, not faster than.
The Mustang STILL looks like this. Welding in subframe connectors now. When that's done, it should start coming together faster. Still to install - shifter, wiring, gauges, shift kit, engine, exhaust fabrication, building a fan shroud. Waiting on oil pan studs, main power switch and a steering wheel.
*whew* - track opens 2/20
OH - and I still need to install the 4:11's in the Falcon!
1967 Falcon 4 door w/351C
Owner built, owner abused.
<font size=-1>[ This Message was edited by: ckelly on 1/12/04 7:31pm ]</font>
I'm working on a new engine for the Capri. This time around it'll be a '68 302 with ported heads and some KB-116 domes. I hope to have it in the car before the track opens in March. I'll be going to a higher stall converter and maybe a set of 4.11s.
1 - 20 of 36 Posts
