I have been considering getting a Performance Distributors DUI or MSD distributor or reusing the stock unit with Petronix. I would like to get opinions on which of these would be best for my application. It will be in a '70 mustang that is street only.
MSD Pro Billet with 6AL box... or if you don't want to spend that much, just get the Pro Billet Ready-To-Run, that's what I've got in my 289 and it works perfectly to 7500 rpm
Ford Duraspark triggering the Multispark box of your choice,the Duraspark can be wired direct or through the Duraspark module.I think this is a very sound set up with easy to get parts if needed and a choice of easy to get caps etc, the single part female cap or the two part with HEI lead connectors.You can get a rebuilt cast iron/steel gear distributor and go from there.I'm a firm believer in making the most of Ford parts,These are still used on the crate engines and theres sweet all different between the MSD magnetic guts and the Ford one.......
