I had a carb problem after trying to get some QF billet blocks calibrated, that led to pulling my intake and discovering it was sucking some oil, checked it all out and replaced the gasket with the fel pro HIPO gasket set and used RTV to seal the ends, start the car and same problem , tried every variiation of blocks and bodies, baseplates etc. no luck, even reassembled the 750 VS holley it used to run and still no luck, pulled the plugs and they look dry and tannish, I do need to adjust the valves but that shouldnt cause the car not to idle, as soon as i raise the rpm the car runs and revs fine, i checked my dizzy at crank and its spot on the money, so I''m at a loss and frustrated as hell after this and to make it all even better the damn thermostat that i just replaced is leaking, Hasnt been a good day, Oh well thats cars, IF you got a suggeation as to where to find this problem I am open to it, any idea will be checked out, THanks and sorry about the long post
