Hi guys, Got a little to aggresive with the gas pedal and hit 2nd gear very hard and the clutch pedal was stuck to the floor. crawled under car and discovered that the metal rod was no longer in the clutch fork of the lakewood bellhousing. This happens often as im using a 5.0L roller block with the z-bar setup. Usually i just grab the rod and pop it back into the fork, But this time there is damage. The spring is missing and the rod feels reall loose. I see that the spring attaches to the fork but where does the other end go... back towards the drivers seat direction or forwards towards the front of engine direction. My car is stuck on the side of the road and i need to get this fixed asap because it is undriveable right now. Any help would be greatly appreciated. Thanks.
