I have been browsing around and have not really been able to find a solid answer, I ran across a set of Mustang Bullet wheels on craigslist and was wondering if they will fit my car. (17x8) I'm pretty sure they wont....
The only mods i have are maverick power steering and disc brakes on the front of the car, other wise its completely stock. Drums in the back, stock rear end.
I know that i will need spacers, but other than that i have no idea.
You wont have clearance problems because they are a larger diameter from stock.
But the problem you will have is that they are off a later car where the offset is way different, so you will need spacers to bring them out towards the fenders.
I'm with Jetfixr320. Bullitts with 1" spacers all around. I'm swapping to 20mm/3/4" rear spacers as the back tires rub the outer wheel well ever so slightly on hard corners or with alot of stuff in the trunk.
