The spec sheet says this cam kit makes power to 5500 RPM and valve float occurs at 6500 RPM, so where do you set the rev limit?
Here's the build-up:
302W bored 0.030 9.6:1 comp. estimated
Stock cast iron heads(ported, gasket matched)
Hypro.Piston(Fed.Mogal, valve relief,flattop)
Edelbrock Performer 289 intake(re-using)
Holley 600cfm 4160(choke&horn removed)
Reconditioned con. rods. w/hvy dty bolts
Tri-Y headers
Scorpion Roller Rockers
Now for the cam:
CraneCams PowerMax H-288 Hydraulic flat tap.
Specs are:
3200-3600 cruise RPM
Basic RPM 2500-5500
Gross Lift Int./Exh. .488
Degrees Duration @ .050 Int./Exh. 226 deg.
Degrees Advertised Int./Exh. 288 deg.
Lobe Separation 108 deg.
Intake Open/Close at .050" 10/36
Exhaust Open/Close at .050" 46/0
gearhead
67 Fastback
Tri-Y headers
Now for the cam:
Specs are:
Basic RPM 2500-5500
gearhead
67 Fastback
