is it required to change the regulator or just smart to do? they used to cost 7 bux, now they want 29.00!
If it's the solid-state type (shorter), it should last for quite a while. If it's the points type, I would replace it. They are interchangeable, so if you have the breaker-point type, I would replace it with a solid state unit.
are you speaking of the condenser?
i dont know what it would be shorter than.
or how to tell. i will probably just reuse it and see if the lights flicker..
