I have been working on the steering column of a 67 Galaxie. When I replaced the wiring within the column, I ended up with one red wire left. Once I removed the old wires, and inserted the new, there were no other slots to place it. It is a solid red wire, which I'm assuming is used to power something.
Does anyone know if the wire is necessary in my 67?
Thanks.
Is it a new switch? I know the switch I bought had one extra wire then the one I pulled out (all the others matched as far as color and the extra was the odd one out). I seem to recall that it was red, I just cut it and folded it over and sealed it with some heat shrink.
'67 Mustangs use the same switch and the only thing I could figure was that was for some other application.
X 2. If EVERYTHING works, even the Hazard lights, then cut and insulate it and forget about it.
I just looked at my 67. There are 10 wires going from the plug up to the switch, none of them are red. X2 on what was said, cut and insulate.
