1 - 8 of 8 Posts
I need to find a flywheel for my 289 I'm putting together. I plan to put a T5 tranny behind it, so I believe I need a 157 tooth with the 28oz balance. I want something that will be good for 7000 rpm, about 350-400hp. I'm not looking for a fancy aluminum one or anything, just something I can put more trust in than what I'd find at the scrapyard.
Discussion Starter · #2 ·
By the way, the engine is a '65 289, am I correct in assuming it uses the 28oz imbalance flywheel and balancer? I've seen a few parts that say they are for '68 and up, which doesn't cover '65. What changed in '68, other than going to a 302 stroke?
did you try jegs and summit?
The 28oz, 157 tooth flywheel is correct for your app. The only cheap flywheel will be a stock one, but I would not want one next to my foot at 7000 rpm. If you want to race, spend the money and do it right.
The only thing at Summit or Jegs is a Hays unit that runs $280. I was hoping to find something in the sub-$200 range, it seems like I should be able to find something decent for that much, but I haven't found anything yet. There's a business selling lots of 289/302 stuff on Ebay, I believe they are CAT parts. They have an aluminum flywheel for ~$280, which I thought was higher than I needed to spend, but it looks like I'll be spending in that neighborhood anyways. Is there any disadvantage to an aluminum one?
edit: Here is a link to what I'm talking about:
http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1833629820&r=0&t=0
'86 Bronco fullsize, 460cid, E4OD w/ Baumannator TCS, 4" Rancho lift, 2" body lift, 35x12.5 BFG AT KOs, 4.56 gears, Auburn posi in the 9" rear, Digital instruments, 600watt Pioneer sound system
<font size=-1>[ This Message was edited by: Motorhead on 6/5/02 2:04am ]</font>
You could get a ford Racing unit from PAW for something around $220. Don't think it's SFI approved though. It's what I'm running in my car.
Discussion Starter · #8 ·
I was searching Summit's web site and I found both the Ford Motorsport one for about $220 and also a Center Force one for $250. Kinda looks like I'm gonna have to spend some dough to get a good one. I plan on getting a Center Force clutch, should I get the Center Force flywheel too? Or, I could still get the aluminum one off Ebay for about the same price. Is there any reason why I should avoid that one?
___________________________
<font size=-1>[ This Message was edited by: Motorhead on 6/5/02 2:49pm ]</font>
1 - 8 of 8 Posts
