1 - 14 of 14 Posts
I´ve already searched through the I-Net but only found something for 289/302.
Does anybody know a adress/link/shop where i can get an intake manifold for the 351W using 4 Weber DCOE Carbs....looks like this...:
Maybe i will go for something crazy....;)
Regards
Mark (already using 2 DCOE Weber Carbs on a VW Golf MK1)....;)
Regards
Purdy....
In my searching, I have found that only two barrel, four barrel, and dual quad manifolds are available for the 351w. I was looking for a tri-power set up, but no luck. Like Dan said, you'll have to use the spacer plates, but they are expensive and, I have read, prone to leaks.
Not cheap but you might check with these guys: MorrisonOz/Ford Manifolds
That Cleveland version that they have is probably worth more than my entire car! But that is one smexy beastie of an intake setup!
On a side note, how do cross ram intake setups compare to our usual intake offerings?
That was a question on a test I took.. not sure if it was when I was getting ASE or not but here's the question.. Not sure if this applies but here goes..
Why do some cars use side draft carburetors and others use down draft carburetors?
Banned
I'll take the test . what they got a ASSE performance test ?
1-depends on type of engine
2- hood clearance
3- this goes with 1- straight shot to the intake valve and would be the #1 reason for performance
No one ever made one for the Windsor block. Even the down draft Weber intake manifold sold by Blue Thunder is modified from the original Ford intake made in '67 for Can Am use. Your only "easy" option is to use the 289 cross ram and the Price adaptors ( well made) as already suggested. OR have one made. You could start with a Ford lightening bottom casting and have a tubular top made to suit. Or a dual quad with two Weber adaptors.
1 - 14 of 14 Posts
