Back in the day....
Many cars had a resistance, a ceramic block (white - about the size of a pack of chewing gum. It had some "putty" looking stuff inside, you could see if you turned it over), which was in the circuit to the coil. You may not see it, 'cause it not there. Most of them were lost, tossed or removed over the years. Either with them or without them... cars seemed to run as good or better either way; (removing them did cause the points to pit earlier, but thats another story, besides points were cheap).
A lot of after market distributor/coil packages said use them or remove them, so the chances are better than 50/50 that you car doesn't have one. With CDI (capacitive Discharge Ignitions) just follow the package directions.
Some of the later models had the resistance wire. If you aren't sure whether the wire has a resistor or not, screw it ... instead of chasing the technical way (DVM measure resistance, consult book for specs)...just cut the wire and run a equal size wire in its place. Probably for the best, since the stock wire is brittle and needs replacing anyway.
<font size=-1>[ This Message was edited by: Beoweolf on 3/10/06 9:50pm ]</font>
