What oil pan is required for the 460 into the 66 Fairlane. The front sump pan doesn't work. Help!
What kind of front sump pan have you tried? A could understand why an aftermarket "deep sump" pan may have problems with the crossmember.
I believe it is a front sump from a 73 truck. It was on the engine when I bought it. The back of the sump hits the k member and the front hits the sway bar.
