I pulled the tranny yesterday to have the flywheel balanced, and while that's going on, I'm gonna tie up some loose ends. The first time around, I got a roller bearing from an '88 5.0 and it barely fit in my crank. I had to pound it in with a hammer, and it's still sticking out about 1/8". So, what's the problem? Did I use the wrong bearing? Should I use the original style bushing? What should I do? I ran the car for a few months like this, I just did the best I could to make sure the bearing was in straight, and just had to make due. Any input would be helpful.
Just put a new pilot bearing in my truck and it fit just like you described so I think you should be ok.I used a socket that fit on the outside area of the bearing and pounded it in with a hammer.I had an extremely hard time getting the old one out so be careful not to damage your new one while you are putting your tranny in and out
I just put a roller pilot bearing in my early 302 crank it went in all the way to the shoulder ont he bearing with no problem. Just a few hammer hits on a hardened impact wrench socket.
Maybe your crank was dirty or damaged.
Sounds like you should be good, your description sounds just like my installation. If you are still concerned you can trial fit the tranny w/o the clutch and disk to make sure the input shaft does not bottom out on the bearing, just a thought. Oh, stay with the roller bearing, it is a much better unit, longer life and less friction which means less heat.
Roller bearings will wear a groove in the input shaft snout....."Oilite" bushing found at Advance Auto Parts works great and won't damage your input shaft!!!
Just a thought....
Cobrajack
