1 - 20 of 29 Posts
Gary: This is kinda throwing me.The bell looks like an early V-8 221-260-289 5-bolt, as best as I can see. The trans case seems to be C-5AS? Most of them end in R or Z. The Falcon, Fairlane and Comet V8s have C-5-OZ . The big cars had C5AZ for the 289s and C5AR for the FEs. IIRC. Bo you have the tag that was attached to the tranny? If so post it. Also let me know if that is an S on the case. Could be a 289 Hipo? I will check.
Ray
A starter wouldn't mount that high in a V8 application. I'll bet it's from an inline six.
A 4 speed toploader? Heheheh. I didn't know you were supposed to count reverse!
Brian, you might be right, but it looks just like the 1964 289 bellhousing I have in my shop. Just went and looked.
Ray
Gary, According to Hollander Interchange it is a 390cid overdrive tranny. Ilooked at the pictures again and see a hole on the left side for the governor. There should be a hole on the right side for the electric solonoid.. Let me know if it is there. Damn, I going blind looking The hole i where the speedo cable goes in. Been reading the book to much. The C5Ar threw me off. My hollander does not go past 1965.
Ray:
<font size=-1>[ This Message was edited by: rayell on 2/4/07 9:15am ]</font>
Discussion Starter #14
Here are the pics of all sides... I'm thinking it's a stang 3 speed...
And the little 3 speed I got with it...
I'm so depressed... My doctor refused to write me a prescription for Viagra. He said it would be like putting a new flagpole on a condemned building...
<font size=-1>[ This Message was edited by: FEandGoingBroke on 2/4/07 9:21am ]</font>
You are right You posted the tag while I was looking at the Interchange. It's strange as hell that the 390 OD number is the same number, according to them.
Ray
If it all bolts up it I am confident that you can make it work. There might be a difference in the length of the front main drive, and cover. The splines should be the same.
You will prolly have to mod the driveshaft if you still have the small rearend.
Ray
<font size=-1>[ This Message was edited by: rayell on 2/4/07 9:39am ]</font>
Been there, couldn't do that.
Your 61' bellhousing is not compatible with the newer transmission shown. Plus the 67' and newer I6 bellhousing that accepts that transmission (Mustang/Maverick/etc) will not bolt to your 61' 6 banger motor. Just like the V8, the back of the blocks changed sometime in 65'. Hint: There is supposed to be an early Econoline bellhousing that does help you to make that transition, but I never tried it. That or replacing the motor with the newer style are about your only solutions. I suggest going to an I6 specialty web site for the details.
The heavy duty tranny pictured was similiar in external design to those found behind the passenger car 6 banger from 67' and newer and you can source some of the other parts from them. Just not the bellhousing. . . . .
I've converted several 66's Stangs which use the same crappy weak tranny that you have to the more modern synchronized one that you bought. I normally found a donor car which was any 6 banger Mustang from 67' and newer. Used to use a lot of Maverick/Comet stuff. I've used both I6 or V8 trannies and both 3 and 4 speed toploaders.
I swapped the flywheels, clutch, trannies, and driveshafts for the newer stuff. The newer clutch is more heavy duty and matches the input shaft splines of the larger tranny which will be different than you little tranny. The splines are also different at the output shaft of the tranny, so you have to change something out there. I've done it 2 ways, by either swapping out the yoke to the newer style, the whole driveshaft, or used a V8 type driveshaft with a later yoke. You also would need to put some thought into attaching your shift mechanisms.
Dennis
65' STANG, 3160 lbs
393W NA, 2.78 Toploader 4 Spd, 9" 3:70 Posi
Pro Comp Heads, Vic Jr. Intake, 750dp, CI Custom SFT, 10.2 CR, 1 3/4" Headers, Lakewood, Subframes, Caltracs
<font size=-1>[ This Message was edited by: dennis111 on 2/4/07 7:21pm ]</font>
Discussion Starter #19
Dennis, am I in luck?
I have a 1970 block in my Falcon. It's not a 61 on ly the car is. The eng. is a 1970 Maverick 200.
I'm going to holler at the Inline 6 club and see what they got for me... Maybe there is an adaptor...
ONe last thing for dennis... Will this tranny shift the same? Can I use my column shifter?
FE
With a 70's block you should be good to go-you shouldn't need an adapter to match the large tranny--just the bellhousing.
The bellhousing in your picture "might" be the right one. Just acquire the other parts from a 67 or newer I6 200ci vehicle.
I wonder how your 70's block got mated to the baby tranny? Perhaps they used a 65-66 bellhousing to make it work.
If you can get the shift rods lengthened, I don't see why you can't continue to use your column shifter.
1 - 20 of 29 Posts
