I guess y'all should have seen this coming. I went back and looked at the spec's on my current valve springs. I'm wondering if I was pushing it to get that what I have gotten out of these even when they were new. A phone "tech" said my current springs just need to be freshened up but I'm not sure I trust that opinion. Frankly, I don't have a clue beyond looking at what the cam spec's recommend.
Current are 132 on the seat, 293 open load, 322 pounds per inch, dual springs with a damper. My cam called for either these or another spring that is spec'd at 121, 343, 370. It seems odd to me that this would have a lighter pressure on the seat. This spring would require deepening the valve pocket a little to get the pressures to spec.
Another valve spring that looks to be perhaps the next step up is 165, 346 and 366. Same dimensions so no extra valve pocket work needed, also a dual spring with a damper. Do I really need these though?
I see some spring spec's that seem heavy on the seat and a bit lighter on the open load and others that are lighter on seat pressure and heavier on open load. I don't understand. It is too confusing for my simple brain.
