OK as some of you may know, I did a cam change last month. I went from a 270H to a 282S. I used the matching lifters and I also installed a new Edelbrock double roller timing chain and a new timing cover. After I broke in the cam I used the same oil that I always use - Mobil 1 with a puralator oil filter.
With my old cam my oil psi was at 60 psi on cold start up, 50 psi fully warmed up while driving, And 25-30 psi at a hot idle. When I would idle I could tap the throttle and the oil psi would rise instantly.
Now with my new 282S my oil pressure is 55 cold, 38 psi fully warmed up while driving, And 15-20 psi at a hot idle. Now if I am idling at 15 or so and take of and start driving the oil psi is really slow to rise... So my oil psi is alot lower than before, And is really slow to rise
I have changed the oil and filter since, And same problem. I have checked it with a mechanical guage and got the same results. What is going on here? I am ready to use this motor as a really expensive boat anchor. Any help would be appreciated. Thanks.
