1 - 12 of 12 Posts
Ok I did a search and read quite a bit of tire and wheels threads.
So, my question, 1964 galaxie I want the widest 15" tire/ wheel on yhe rear I can fit with factory suspension except I have air shocks. Will a 15x8 or 15x10 fit with 4.5 offset?
On the front, same thing with no rubbing of fenders or ball joints. open to all suggestions.
I don't want a super tall tire but one that look proportional and fill the wheel well nicely. I want some good looking meats on there, make sense?
Thanks for all the suggestions.
HMMM...after that burnout you're wanting to buy new tires :eek:???
Before I changed my rear end I had 245/60/R15 Cooper Cobras on 8" American Racing wheels w/3.5 backspace and had a heck of a time getting them on and off. On the front I have 215/70/R15 Cooper Cobras on 7" American Racing wheels w/3.25 backspace and they rub a bit on my inner fender lip when I hit a bump while turning the wheel. There may be some who will argue this point BUT that is the biggest I would use ;).
they rub a bit on my inner fender lip when I hit a bump while turning the wheel. There may be some who will argue this point BUT that is the biggest I would use ;).[/QUOTE]
Just put new BFG 255-60-15 on a 8" Cragar on the back of my 64 2dr fb galaxie(but I had to let all the air out of the tires to get them on) 3.5" backspace, and I put 225-60-15 on a 7" Cragar on the front.Only bad thing is you can't rotate the tires.They sure look good though.....It seems someone told me that the biggest tire for the back of a 64 would be 295-50-15 and there is 26 5/8" clearance in the rear. I haven't had any rubbing trouble so far on the 225-60-15's in the front,knock on wood..... hope this helps....
Red
I ran 275-60-15 on the back of my old 64 Galaxie most of the time. I had plenty of space in the wheel well. On the front I juggled different tire sizes to get the look I wanted, but I always ended up rubbing the frame behind the wheels on lock to lock turns. But then I also had 69 disc brake front spindles on there and that may have thrown it off a bit. Even with a 205 tire it would rub.
For a while I had a set of 15x9.5 wide steel rims that I ran 295-50-15 tires on for the back. Those were very close to the leaf springs - within an inch or so - but never rubbed. Either way, with the 275-60 or 295-50 on the rear you'd have to jack up the entire back of the car, unbolt the shocks, and let the suspension drop if you wanted to get the tires in & out of there easily.
Red[/QUOTE]
The 225/60/15 makes sense because they are shorter :).
With the 245/60/15 I had drum brakes and I had to squeeze them in from the back. I didn't have to deflate them though :D.
I'm running 295/55/15 MT ET Streets on the back now, but I had the rearend narrowed 2" w/ disc brakes and am running 1/2" spacers to bring them back out. It has 2" wheel studs so the tire on drivers side is a 'bear to get on, had to grind 1/4" off the inside of the fender lip. I also have to have at least 90 lbs of air in my shocks and have to raise the rear end of the car a bunch and put it on jack stands. I could probably unbolt the shocks but they are air shocks. If I would cut 1/4" off my studs they would go right on.
I,ve been playing with the tire/wheel combo on my 64 for 4 or 5 years now. This is what I have found to work so far.
I've run a 275/60/15 on an 8" rim with 4 1/2" backspace.
A 28"x 10.5" slick on the 8" rim with 4.5" backspace but you need a spacer.
Here's a shot with the 1/4" spacer. Suprisingly it never rubbed ever. I used a 1/2" spacer befor I switched to a 10" rim.
The tire I run on it now is a 28"x 12" M/T S/R radial. Its on a 15 x 10 Pro Star wheel with a 5 1/2" backspace. I had to use a 1/4" spacer to bring it out to perfect.
This was all with the standard hub brake. I now have disc brakes on the rear which brings the mating surface out 1/4" so I dont have to use the spacer.
Here's a pic as it is at the moment.
I have the 2" comp wheel studs which make fitting a little more difficult.
You will have to undo the shocks and lift one side at a time to fit these bigger tires but thats no biggie.
On the front I've run up to a 235/60/15 with no rubbing. (Manual steering). I currently have the M/T S/R 26" x 6" tire which seems to work well. I use a 26" front runner for drags.
I do have an extra leaf in the rear and custom heavy duty coils in front.
Please feel free to ask if you would like any more info.
fat64,
You have really done your homework. Your clearance is down to the knats a$$. What's your secret to mounting those monsters :)?
Great burnout, which tires were you using?
fat64,
They go on quite easily with both shocks undone and lifted on one side only.
Those tires WERE a near new pair of 275/60 BF Goodrichs. They were mostly gone after that.
I guess thats what happens when mates come round at lunchtime for a few beers.
Here's them being "finished off". lol.
fat64,
Those 275/60 BFGs didn't stand a chance with a 521 and a few
'Fosters' ;)
Danv, nice stills...how many 'Fosters' did it take to convince him to destroy his tires :).
These ones stood even less of a chance. lol!
As you can see........
Strangely enough you cant buy Fosters here where I live. Maybe its export only?
1 - 12 of 12 Posts
