im just wondering if any of you guys know if the valve steam eals on my windsor sr heads can be replaced with just regular 302 seals or if i have to use a special kind with the paper work that comes with it it lists some numbers but the dont refrence to anything and i would rather run the teflon type seals rather then the unbrella type so im wondering if any of you have replaced them with regular ones or know what they should be replaced with
thanks jeff
can you measure the OD of the guide, its probably .510 or .530. You can buy viton positive seals for 15 bucks and run em. Just make sure you have inner spring clearance and spring clearance when valve is fully open.
nope, your good to go, just double check the inner spring clearance
