Assuming I've got the correct blockplate en flexplate, will a pan-fill C4 fysically fit in the '65-'66 tunnel?
Since people install larger AOD's in early Mustangs all the time, I assume it's not a problem, but I'd like to make sure :)
It will fit.
Depending on the vehicle the original dipstick and tube came from - you may have to find another compatible model version, a close-fitting rigid aftermarket version (TCI, PA, etc.), or just use a flexible aftermarket version (Lokar).
