do you guys know if a windage tray will fit with a stroker crank or do you have to buy a specific one for a stroker and do you have any recomendations on one to use
thanks jeff
I installed the Ford windage tray on my 347 with no problems.
I used the one from DSP made specifically for my 331 stroker. It is made from aluminum and bolts directly to the DSP aluminum girdle.
Absorbs more harmonics vibration than a steel unit. And looks good too.
A very high quality unit.
Hey guys,
I installed a canton model 20-930 and the 20-241 stud kit on my 289/333 this past winter. Just had to lift the rear of the screen slightly to clear the crank throws. Easy bolt-in.
Good Luck
