keeps oil off the crank and in the sump
The crank counter weights need to spin in air and not oil. Do this little experiment. Wave your hand back and forth in open air. Now do the same thing with your hand under water. This is another reason why it's important not to add too much oil.
I hope this makes some sense.
On top of that, oil is even more viscous than water.
The drag forces can be immense, even with a little splash from the pan.
just what woody said. It keeps the crank from slinging it all over creation, and frees up a couple of HP too.
This is another one of those things you hear about all the time. On the dyno, there is NO gain untill you go past 6500 RPM. then it does not do much untill 8000 RPM. Usually , just draining some oil out of the pan can make the most differance.( Got to br carefull here)The tray might make more gain in a drag car when it is accelerating. JOE SHERMAN RACING
