OK, as I'm finding on my car most things are blissfully original but old. This makes life simple with my diagrams. I've replaced every wire under the hood one at a time with shiny new ones run inside looms and beautiful. I thought I was out of the woods on the hard stuff... I was wrong. I fought my way through some crazy hack jobs and splicing and right now am working on the wipers and not only does the switch not work, but the whole moulded part of the white inner dash has been cut out to make room for two toggle switches I guess one used to control the wipers and one was for the washer pump. I've installed an aftermarket reservoir with pump with internal pump and wired it right to the firewall where it's supposed to go. But I've got this mess of wires with no switch and already cleaned up the half a$$ toggle switch holes from where they were stuck through with washers to hold them from going through the rectangular hole for the original switches. I've filled and sanded all the gouges and blocked all my indicator light holes with brushed aluminum and did the same to the side where the wiper switch used to be now I have a blank canvas with carbon fiber covering the once plastic "woodgrain" and aluminum behind all the holes. Should I look for some era looking toggles, should I use the little red push button that came with the washer kit I wanted stock, but don't want to pull the whole thing apart again. Ideas greatly appreciated
Sent from my Autoguide iPhone app
