I purchased a drag car about 5 years ago & did nothing to it but let it sit. I am now getting to it & trying to get it going & i have a lot of questions.
I need to get it running but it has no alternator, so by time i got it turned over enough to choke/fire it up & get it running the battery has lost to much and isnt strong enough to do it again. I am using a new 12v 1000ca interstate.
I thought about maybe hooking up two battery's but it will still drain them & im sure i'll be stuck where im at now, having to wait around for battery's to charge so i can try to start the car.
How do i know what parts i need for my motor. Do i have to get them year specific to the engine? or can the front pulley, alternator bracket, (& what else?) be from any windsor.. Or do these parts even need to be specifically from a Windsor or even a ford motor?
I thought about putting an alternator on it but I'm not sure where to start. i need brackets & pulleys, i would need to replace the current electric water pump correct?
Battery is currently in the trunk, if i add the alternator is it going to be ok that the bat stays in trunk or would it be best to put it up front
What would you do? If i go to a salvage yard & want to get everything i need to hook up an alternator, What do i need to get? From a specific vehicle/engine?
1982 Mustang GT-351W-C6 trans-B&M Z Gate-8 Point Roll Cage-Bucket Seats w/5 point harnesses-10 Gal Fuel Cell-Holley Dbl Pump Carb-Full Frame Connected-Drag Shocks-Et Drag Tires/slicks-Front Runners 6" Center Lines-Accel Coil-Front Brake Line Lock-Electric Water Pump, Holley Blue Fuel Pump & Fan
