My good friend has a 2003 Windstar and the transmission went bad or so that's what the mechanic says. He was told it will be $2300 for a rebuilt one to be install.
Symptoms : It wont go in drive or revers "All the gear fill like neutral", It shows way to much fluid when check with the dip stick. He claims no fluid was added by him or the mechanic. No Check engine light or codes.
I think the torque converter went bad and push all the fluid into the tranny.
What do you think????????
