I recently installed a 2 speed wiper motor from Stan the Ford man. It came with a complete wiring harness. Now I’m trying to install an intermittent switch/governor from a donor mid 80’s ford truck.The plug harnesses don’t line up, so I will have to splice in. I don’t know what each terminal is, or what color wire does what. The donor assembly has 6 wires, my existing harness has 7.
From the donor switch directly to the harness plug I have;
Blue w/ red stripe ( park?)
Black w/ white stripe
Black
From the donor switch to the control unit;
Red
Black
Black w/ purple dashes
From the control module to the plug harness;
Red
White
The harness which came with the motor has
Orange w/ white stripe ( This is the hot from the ignition switch)
Green ( splits into 2 leads at motor end
Red
Blue
Yellow
White
The orange and black/white plug into the dash harness and also have an additional black lead which is probably the washer pump.
My color diagram doesn’t label any connections by name.
