1 - 18 of 18 Posts
This is what you need.
C50Z-7976-A
<font size=-1>[ This Message was edited by: Stuarta on 4/26/07 5:31am ]</font>
That looks like the 164 tooth bell housing. Are you sure that it is for a 157 tooth flywheel?
Paul
wont any bellhousing that is from a 302 mate up to a 351, as long as the bellhousing is 5 7/8 inches tall and 157 tooth?
Discussion Starter #8
thank you, I am still looking for one though, if someone has and extra they want to sell that will fit my application id appreciate it!
On 2007-04-25 22:42, Stuarta wrote:
According to this place it will work.
http://mmerlinn.tripod.com/trans/fdc4f/fd6c4bhm.htm
That does not look like a small C4 bell. They are very close in appearance, but the starter holes will be located farther out by a bit, about 3/4". Maybe that's a 6 cylinder item.
<font size=-1>[ This Message was edited by: ckelly on 4/27/07 11:45am ]</font>
That is a C4 small bell. It fastens to the transmission via the pump bolts.
The larger version used separate bolts.
Any 302 bell will fit the 351W. Most of the smaller cars use the 157 tooth ring gear. The bells are easy to come by - I have one here that will go to the recyclers when I clean out the garage next week - I'm in Seattle if anybody wants it come and get it.
Paul
1 - 18 of 18 Posts
