Start with the basics.
1 - Pull the plugs and see if you dropped them and closed the gap up
2 - Check the wires with an ohmmeter and see if they are dead
3 - Check compression
4 - Check valve adjustment
Then look further
Check the distributor cap inside contacts, outside contacts, and both terminals ends of the spark plug wires.
