Ok...I'm shooting a single stage urethane paint. I add the activator and fish eye eliminator, but the tech sheet states that further reducing isn't necessary ;ie a reducer but can be used if desired.
#1 What situation(s) would require reducer?
#2 Using a 4:1 ratio, what amount of reducer would I add? I only mix a quart at a time,btw.
I'm at 5,500ft elevation and shooting at between 70 and 80 degrees. Would reducer help the paint lay down better?
TIA
TIA
