Is there a difference between big and small block toploaders? I know you can get ones with the 1-3/8" input vs the 1-1/8", and 25, 28, or 31 spline outputs. Is there a difference between a small input toploader that was installed behind a big block, and a small input toploader installed behind a small block?
I'm thinking if I can get a small input toploader reasonable, I can always retrofit the large input shaft and bearing retainer ala David Kee's parts.
I'm also talking strictly wide ratio tranny's here.
Thanks!!!
Pat
Thanks!!!
Pat
