Carter AVS/AFB Question! ! : Does the Ball Have A Spring?
1 reading
868 views 1 reply 2 participants last post by  heavy
#1 ·
Is the Ball under the pump jet supposed to have a spring as well? (If so, Mine doesn't) What would it change?
#2 ·
No, there isn't a spring under the accelerator suirter, just a ball, or a needle on older carbs. I think the ball is there to keep the accel pump from sucking air as the piston returns to it's home position. There might be a siphoning issue also, dunno. Just make sure the ball is in place.
